Hi Jeremy,
It's a judgement call; I recently had a broken screen I was going to fix on a Samsung for a friend, but unfortunately the screens were still going for over $130 for a replacement. So I thought I'd give a front glass kit a shot. It came with a lot of tools and equipment and looked doable, but unfortunately I wasn't able to get the shim in between the OLED and the front glass correctly and ended up damaging the OLED, so I ended up replacing the whole screen anyway. But for $30 it was worth a try, to me at least.
There's a company that appears to be specializing in front glass replacement kits, but looking at their catalog it doesn't appear they offer a kit for your A54 yet. I see one that lets you pick between A50, A70 and A80, but not the A54. Although it says it's "Compatible with all carriers/sub models of Galaxy A50/70/80", I suspect that doesn't include models in between like your A54.
Patent Pending DIY Samsung Galaxy A50/70/80 Front Screen Glass Repair Kit – ExpertCellDIY
However, they do sell a universal kit where you supply your own front glass and they give you everything else you need.
Universal Front Screen Glass Repair Kit (Just add a front glass!) – ExpertCellDIY
Couple that with a cheap glass from AliExpress and who knows, you might be able to fix your existing screen for around $35 USD.
Replacement Kits For Samsung Galaxy A54 Touch Screen Front Glass Panel LCD Outer Lens Glass With OCA - AliExpress
So there's what you'd need to know to attempt a glass only repair on your own; my suggestion would be to go ahead and buy a replacement screen then afterwards you can take on the glass repair at your leisure. Or if you're not in a hurry, you can go for the glass repair and order a new screen afterwards if it doesn't work out.
Either way we'd love to hear what you decide and how it turns out for you! If you give the glass repair a try it would be great if you could take lots of pictures, then we could see about putting together a guide to that repair for people who follow after you who have the same issue.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
