charger port is broken
charger port is broken can i fix it
Ist dies eine gute Frage?
According to the documentation, your charging port is a fairly standard micro USB port, but it is mounted on the motherboard so replacing it will require you to remove the motherboard first.
VTech InnoTab Max Motherboard Replacement - iFixit Repair Guide
Once you have it out, you will have to be somewhat handy with a soldering iron in order to remove the old port and replace it. Here's the part you need to swap out.
The hard part may be locating a suitable replacement part; the only one I found that says it's specifically for the InnoTab Max is on eBay in the UK; here's the listing.
VTECH INNOTAB MAX MICRO USB CHARGING CONNECTOR SOCKET PORT DC JACK BLOCK - eBay
Or you could take a shotgun approach and just buy a bag of assorted ones like I did to fix a room filter fan for my son.
If you're somewhat experienced at soldering this shouldn't be too bad of a repair, but otherwise you might have to find a local repair shop; most of them shouldn't have any trouble swapping this part out for you.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 31
Insgesamt: 270
