Warum versteht mich keine auf Lautsprecher?
Beim telefonieren gibst probleme mit meinem Mikrofon nur wenn ich auf Lautsprecher bin.
Wie kann man es reinigen ohne irgendwas kaputt zu machen? 🫡
Ist dies eine gute Frage?
Hallo @apollor
das ist unangenehm :-(
Leider gibt es keine Anleitung dazu hier im Forum und ich kann im Netz auch keine Reparatur- oder Teardown-Videos dazu finden (jedenfalls keine, bei der alles heil bleibt).
Im Asus ZenTalk-Forum habe ich das hier gefunden: Rog phone 6 pro microphone issues - ASUS - ZenTalk - 360070
Vielleicht magst Du dir das mal anschauen und ausprobieren.
Thanks for bringing this to our attention. I'll forward the issue to the R&D, however, before I do that I'd recommend you perform an SMMI test to assess the microphone.
- Open the Calculator app
- Type ".12345+="
- Select Single Test under the SMMI Test
- Run a test for BoardMic1-2-3
Also, could you please share a log file?Please follow the below steps to enable the built-in log tool (Bug reporter).1.  Open “Calculator APP”2.  Enter “.19595+=”3.  Select the Log type according to the type of issue you want to capture. “Sound, call audio, and recording”4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".6. It takes several minutes for the log to generate. You can exit and do other stuff in the meantime. A silent notification will tell you once the process is done. Tap the notification and then the share button to upload the file to Google Drive and share the link with a moderator. Just make sure to change the permission first so that everyone with the link has permission to view it.Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb)
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 9
