Zum Hauptinhalt wechseln
Apples neues Format der 14er Reihe verfügt über ein 6,7" OLED-Display - wie das Pro Max - ansonsten aber über die gleichen Funktionen wie das iPhone 14 mit einem Zwei‑Kamera-System und dem Bionic A15 Chip mit einer 5-Kern-GPU.
What might be the possible soln to this log below
Bildinhalt anzeigen:
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I currently have this same issue. 0x400000 is for the wireless charging coil flex. My rear cameras and flash are not working either, do yours? I have tried replacing the wireless charging coil already and it did not fix this kernel panic.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Unfortunately yes I have the same problem , no flash and no back panel. I don't know what to do to make it work . I haven't found a solution yet . I tried to put an aftermarket rear panel on it , but it was probably the panel that was faulty . Did you try to fix it with a factory part ?
von
Yes I ordered a new rear camera and wireless coil to see if either part was faulty and causing the others not to work. I also tried 2 different back panels and none of the parts fixed the issue with panic. Im starting to think that its not the camera or the wireless charging flex and actually an issue with the logic board that has disabled those circuits. I have done multiple restores even with the new parts installed and that didn't fix it so Im out of ideas.
von
Antwort hinzufügen
Ernő Németh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 351
