Zum Hauptinhalt wechseln
Das iPad der 5. Generation kam im März 2017 auf den Markt. Es ist mit WLAN und LTE mit 32 und 128 GB Speicheroptionen erhältlich. Es verfügt über ein 9,7" Retina Display und einen 64-bit A9 Prozessor.
iPad 5th generation stuck on boot loop after the latest ios update
I have a 5th generation iPad, and when the latest iOS update came out, I think it was iOS version 17, and the update failed and now is stuck on boot loop. I took it to the repair shop but they said they couldn't fix it.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
Hello, have you attempted to hard reset your iPad, or recover it via the recovery mode?
von
@jmehnert
Yes, i did try that and i also tried downgrading the ios version to the previous version via itunes but still no results
von
@gautamkc Did the repair shop give any specific reason they couldn't repair the iPad? Did they attempt to replace any specific parts?
von
@jmehnert not really they just said that they couldn't repair it and i never bothered asking
von
Einen Kommentar hinzufügen
1 Antwort
If you are able to, I would take your iPad to a different repair shop and see if they can find anything wrong with either the battery or the motherboard. Otherwise, if you're ok with doing so, I would try some of the advice offered by @refectio on this question. To give the spark notes summary, I would try to use 3uTools to force the iPad into Recovery Mode, and try and see if updating the firmware helps the issue.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Gautam Kc wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 18
Insgesamt: 241
