Zum Hauptinhalt wechseln
A budget Realme phone, released August 14th, 2020. It packs a 6.5" 720p IPS screen, a Helio G35 chipset, and up to 64GB of storage. It also features a third 2MP camera and fingerprint sensor, which are absent in Realme C11.
Phone got wet and can't open
I woke up when I saw my phone is really wet, I believe it's because of the rain, I remember I put my phone where there is a leak of the rain, I tried to open it but it only last for 5 seconds before everything got turned out to black screen. My Mom plug in the Charger because she thought my phone is just doesn't have any battery or power at all, and then my phone didn't work anymore.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Mobile switch on nhi ho rha h
=== Update (06/04/24) ===
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @gerseantonlopez
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a teardown video that may help
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Gerse Anton Lopez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 286
