Zum Hauptinhalt wechseln
Launched in the first half of 2022, the Asus TUF Gaming A15 FA506IV is based on an AMD RYZEN 4000 CPU, NVIDIA RTX or GTX GPU, and a 15.6 inch 1080p display.
Wifi connection always disappearing
It happens everytime I run my laptop for a short amount of time and it has been really frustrating. Its either disappearing wifi icon or cant connect jacksh*t.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Hi @yfanthenial,
Have you checked that the latest WLAN drivers are installed?
Try using the laptop as close as possible to your network router i.e. <20cm and check if you get a stable WiFi connection.
If so, there may be an antenna problem (loose connection) in the laptop.
Here's a teardown video that shows the WiFi antenna being disconnected from the WLAN card at ~2:20 minutes into the video that may help.
You can also download, install and run this free WiFi sniffer program¹ to see if signal interference may be the problem.
The program will tell you the signal strength of your network (and any other visible networks that can be detected by the laptop). The value of the signal is in -dBm so the higher the numerical number, the lower the actual signal strength is. Here's an article that explains it better then I can.
Having a low signal strength can cause instability in the connection. Also sharing the same WiFi channel with another network can also cause problems if the signal strength of their network is high in relation to your network. If there is then one way to overcome this is to change the channel in your router (see your router documentation) to a quieter channel i.e. one with no or the least appearances as shown by the program. Most network routers default to channels, 1, 6 or 11 straight out of the box and most people don't bother to change it when setting up their network.
¹I think that to avoid having to sign up, scroll down to inSSIDer 4 for Windows and download it there as this version is sufficient for what you want.
War diese Antwort hilfreich?
Bewertung 2
hi @yfanthenial, @jayeff
i have suffered from this problem after some windows update. this issue irritate me when i play the game. i have applied the tons of the solutions but any kind of solution not working.
one day i decided to check the physical connection of the drivers.
i changed the location of my SSD to second slot of the motherboard.
i dismantled the WIFI & BT driver, and cleaned the connections of the driver, after that i have again installed the physical diver to the mother board.
guess what i got the permanent solution.
after that WIFI & BT never disappear again.
Bewertung 0
Uninstall your Wifi driver, and restar your laptop
Bewertung 0
So ASUS TUF A15’s Wi-Fi keeps disappearing, first update your Wi-Fi driver through Device Manager or ASUS Armoury Crate. Disable power saving for the Wi-Fi adapter (Control Panel → Network Adapter → Properties → Power Management). In Device Manager, uncheck “Allow the computer to turn off this device to save power.” Also, ensure your BIOS and Windows are fully updated. Try forgetting and reconnecting to your network or resetting network settings. If the issue persists, reinstall the driver or test with an external USB Wi-Fi adapter to rule out hardware faults.
Bewertung 0
The problem is because of overheating. The WIFI card is situated right under the HD. The motherboard has 2 slots for a HD (one on left side and one on right), I switched the HD to the other slot (you only need to remove the back panel for this) and no problems since. Also didn't need to mess with BIOS in anyway, the system recognized the HD right away.
Bewertung 0
Antwort hinzufügen
Yfan TheNial wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 95
Letzte 30 Tage: 342
Insgesamt: 2,341
