Zum Hauptinhalt wechseln
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Fragen Alle anzeigen
Possible to upgrade Interconnect Board?
Wondering if it is possible to upgrade the interconnect board with one from a newer model? I saw this question asked once before but with an unsatisfactory answer...
And if it IS possible and i could thereby lose the Pata connection from the optical drive and gain a Sata connection would this sata connection still be limited in speed (ATA100 speeds)?
Thanks in advance!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
1 Kommentar
What are you trying to accomplish?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
According to this vendor they all use the same interconnect board.
If this Answer is helpful please remember to return and mark it Accepted.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks!! Apparently I need to work on my googling skills..... I missed that one. And what i'm trying to accomplish is adding more storage but making it easy for myself with regards to connectors and what not. And general interest as well because I like fidgeting with the thing :-)
von
You can go that way or a self-powered USB Hub will connect many devices.
von
Antwort hinzufügen
Nico wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 505
