Zum Hauptinhalt wechseln
The Dell G15-5510 stands apart from the 5511 by its 10th Gen Intel 10200H processor and GeForce GTX graphics. It hosts a wider range of ports, and it built with a sleeker design without sacrificing much performance.
I change my battery and is now working
I change my battery on my dell g 15 5510 with exact same specs 69kf2 and the laptop is not recognized the battery and now the battery led is flashing amber and white flash rapidly. This the battery that I ordered Dell 69KF2 Battery
Replace a 7167 mAh battery compatible with a Dell 69KF2 laptop battery. 86 Watt Hours (Wh). 11.4 Volts (V). Part #DVG8M, 8FCTC, P8P1P Bild
Produkt
Dell 69KF2 Battery
$89.99
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
The Dell support page (below) tells you how to fix this problem. scroll down to where it says "replacement battery is not recognized" scroll back up to the "expand all" then back down to the now visible instructions.
Good Luck!
Your Link: https://www.dell.com/support/kbdoc/en-us...
War diese Antwort hilfreich?
Bewertung 0
Hello, did you return it or managed to make it work. I have the same issue
Bewertung 0
Antwort hinzufügen
Mihai 18 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 48
