Zum Hauptinhalt wechseln
Smart-Lautsprecher Google Nest Audio
Device won’t power on
One day my speaker just disconnected from my home wifi , after unplugging it and switching it back on it was stuck in a boot loop for about a month, after a handful of forms just suggested to leave it unplugged for a while , the problem will fix itself . Well it's been 3 months now , (2 months constantly no power) and now the speaker is not turning on at all , I tested the power supply and it is still giving out 24V, no lights turn on , no sound is coming out and the mute is still unresponsive , I tried countless times trying to factory reset it while it was stuck in a boot loop but had no luck
Has anyone experienced this problem and did anything resolve it ?
Im considering repurposing the speaker and turning it into a bluetooth speaker
Any thoughts or suggestions?
Ist dies eine gute Frage?
Bewertung 4
2 Kommentare:
PS, im situation in South Africa and google doesn’t support any African countries so Im kinda left in the dark over here
von Teilen
A friend have the same problem. I've disassembled it and I think that the problem should be secondary board that doesn't supply voltaje to all the rest of tiny electronic components (AC-DC adapter is 24v and uC typically uses 3 or 5v. I've just made a question in teardown section. Hope I get some feedback 🤞
von Teilen
Einen Kommentar hinzufügen
1 Antwort
Exact same problem here. I'm in Germany, tried everything with Google support and they say it's a common problem but no warranty available. Such a expensive premium device and Google ghosting me. Here is my video: https://youtu.be/8yviFiWhgPE?is=IcKSjrI1...
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Google support answered:
Thanks for reaching out to the Google Nest Customer Care Team.
Here are some steps you can try to resolve the issue:
Plug the speaker or display into a different wall outlet.
Unplug the power adapter from the outlet and the speaker or display.
Leave it unplugged for 20 seconds.
Plug the power adapter into the speaker or display.
Plug the other end of the power adapter into a wall outlet that works.
Check for any LED lights on the speaker or display.
If you have a second speaker or display, you can try to use the power adapter from the one that currently works.
von Teilen
Dear Google Nest Customer Care Team,
Thank you for your message. I have reviewed your assessment confirming that my device has an internal power issue after exhausting all troubleshooting steps.
While I acknowledge your statement that the device is technically out of its standard warranty period, I find the refusal to provide a solution unacceptable for the following reasons:
Confirmed Hardware Defect: Your team has explicitly confirmed an internal hardware failure. This is not a result of wear and tear or accidental damage, but a failure of the device core components.
Product Lifespan Expectations: A expensive premium Google speaker should have a longer functional lifespan. A total failure short after the warranty period suggests a latent defect in build quality.
Environmental Responsibility: Simply declaring a confirmed hardware defect as "out of warranty" and offering no repair or replacement path creates unnecessary electronic waste. This contradicts Google s public commitment to sustainability.
von Teilen
Antwort hinzufügen
Andrew Ross wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 108
Insgesamt: 903
