How do I remove the door on my Samsung ME21M706BAG
I have a Samsung ME21M706BAG Microwave with a faulty door. I need to replace it, but I can't figure out how to remove it and there is nothing useful in the user manual.
Ist dies eine gute Frage?
Well, if anyone ends up needing to know, I figured it out through trial and error.
Unplug the microwave.
Open the door
At the top of the microwave, there is a plastic vent. Remove the two screws holding in place and pop it off.
On the left side of the microwave at the top, there is a wire harness attaching the microwave to the door. Unclip it.
Now on to the door itself. There is a black, plastic frame held onto the inside of the door without screws. Using a flat head screwdriver, pop that thing off. BE CAREFUL as you can crack it easily. If you're replacing the door, go ham, otherwise, use caution.
Once that plastic piece is off, you can simply lift the door off the hinges.
GOOD LUCK!
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 18
