Zum Hauptinhalt wechseln
Repair and disassembly guides for electronic keyboards.
20 Fragen Alle anzeigen
Yahama PSR-82 DC power jack part number
Am trying to fix a Yahama PSR-82 keyboard, the power jack is loose, and the keyboard will work if you hold the adapter at an angle. I have done a lot of searching trying to find the service manual (the Yamaha support sites seem only to have the user manual available) to get the right part number for the DC jack so I can order a new one. If anyone has any tips for online resources that may have this info that would be amazing.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @karl93324
Given that the PSR-110 uses the same PA-3 AC adapter as the PSR-82, perhaps the DC-In jack would be the same one.
Search online for a 2.1mm x 5.5mm pcb mount DC socket (examples only to show part)
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Thanks for your suggestion jayeff, I will investigate further and see if I can get the right part.
von
New part now soldered in, and working, thanks again for your help @jayeff
von
Antwort hinzufügen
Karl wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 29
