Zum Hauptinhalt wechseln
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
Shoots only black photos.
Hello, I recently bought a secondhand Canon powershot G11 hoping that I can revive it. I bought it a new battery and a charger. Once I opened it, it work perfectly. buttons are fine shutter is fine. The only problem is, it shoots black photos only.
How do I fix this?
Thank you.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @danielledg
Have you checked the image colour settings, you didn't say?
See p.82 of the user manual
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
I did, and it still shoots black photos.
Also screen started to turnoff and on 3 times and start again
von
@danielledg
Try a power reset in case the firmware got corrupted somehow.
Turn off the camera if on, then remove the battery from the camera, then press and hold the camera's Power On/Off button for a full 30 seconds and then release it. Reinsert the battery and check.
von
Hi, I did what you said. its still not working. I'm starting to feel that its the sensor needs a fix. Thank you so much.
von
@danielledg
Just clarifying that downloaded images taken by the camera and viewed on a computer are in black and white as well as what is shown in the camera's LCD screen?
Did the seller state that it was fully working?
If not contact them and ask for a refund or a discount at least.
von
Antwort hinzufügen
Danielle.DG wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 37
