Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
iPhone 3GS displays charging symbol but isnt accepting charge
My 3GS is syncing but not charging the replacement batteries. It displays the lightening bolt but the percentage of charge decreases as you would expect when on standby. This is both with the genuine wall charger and cable, in both a wall sockets and PC's.
I have had 3 batteries now (from 2 different suppliers) which I assume arent all duff. All are the 616-0435 battery (which is compatible for all 3GS models). When installed they all showed a decent charge, but then drained and wont charge up again.
With the phone able to sync (with battery power), I have reset the phone, restored the phone, gone into DFU mode and reinstalled the firmware/software from stock and old downloads (deleted out the old and re-downloaded). I have set the phone up as a new phone and restored from back up. None have resolved the problem.
Can it be possible my dock connector flex is faulty? Or is it likely a logic board issue?
Or is there another problem?
Many Thanks in Advance.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Very good diagnosing! It seems that if you have replaced the battery several times and restored the firmware with still no luck, the issue probably lies with either the Dock Connector or the Logic Board (like you said).
Your next move (cheapest) would be to replace the dock connector, purchase part here.
If this does no work then you will have narrowed down the fault to the logic board. If this is the case then you will need to purchase a new iPhone as new logic boards are next to impossible to come by when sold separately. You can search for a 2nd hand logic board on eBay, however if you do this then make sure you have visual proof from the seller that it is completely functional.
Personally i would throw out the entire phone and upgrade to the 4S :P If you buy the iPhone on a 12/24 month plan, you can get the phone fairly cheaply without outright purchase.
Hope this helps!
Martin
iPhone 3GS Dock Connector Bild
Produkt
$19.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have replaced the dock connector to find the same result; syncs with iTunes, connects with both USB and wall chargers to show battery 'plug' fully charged icon-but won't take charge and drains at a normal rate until it dies. The battery starts off at 4.2V and drains to about 2.9V.
I have tested the continuity on the logic board, to find the fuses are ok (No Power, No Charging, No iTunes).
Any other ideas please??
von
No, all replacement batteries are crappy and last you little time. You'll spend more on replacement batteries than just taking it to apple to replace.
Bewertung 0
Antwort hinzufügen
Steve wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 5,028
