Hi @fullofquestions,
What are the temperatures in each of the compartments?
Can you hear if the evaporator fan inside the freezer compartment is running? It will be operating as long as the compressor motor is running.
Try opening the freezer door and manually operating/releasing the door light switch to hear if the fan turns on and off.
If you can't hear the fan operating, this could be due to either a faulty fan, faulty fan power supply or perhaps the fan is iced over, stopping it from operating, due to defrost problem.
To check, remove the panel, inside at the back of the freezer compartment. Here's a video that in general may help.
If there is ice build up over the fan, evap unit etc., this could be due to a faulty defrost heater, faulty defrost timer, a faulty defrost thermostat or perhaps there's a blockage in the drain tube leading from under the evap unit to the evap pan under the compartments, near the compressor motor, preventing the defrost meltwater from draining away
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare
Hi @fullofquestions
What is the model number of the refrigerator?
von jayeff
Model #Abb1921DEW
von full of questions
