@asepusup it may already have a short circuit on the circuit board. Always remember to immediately turn any device off after water exposure. Anyhow, try this.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for this phone, use something like this video to help you disassemble your phone. remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Let us know what the outcome is. If you still have no luck after cleaning, you will need to check the circuit board. For that you will need special tools and have the skills to read schematics (if available) as well as know how to solder very small components on a highly populated board.
Translation
@asepusup mungkin sudah ada korsleting di papan sirkuit. Selalu ingat untuk segera mematikan perangkat apa pun setelah terkena air. Bagaimanapun, cobalah ini.
Untuk saat ini, Anda harus berhenti mencoba mengisi daya, menyinkronkan, atau menggunakan ponsel Anda. Hal ini berpotensi memperburuk situasi. Hal ini dapat semakin merusak ponsel Anda.
Langkah pertama yang akan saya ambil adalah membongkar ponsel Anda. Karena iFixit belum memiliki panduan untuk ponsel ini, gunakan sesuatu seperti video ini untuk membantu Anda membongkar ponsel. lepaskan papan utama dan papan pengisi daya. Anda harus melepas semua pelindung EMI. Jika Anda tidak melepaskan pelindungnya, Anda tidak membersihkan papan.
Perhatikan baik-baik semua komponen dan konektornya. Carilah korosi besar, evaluasi pin pada konektor, dll. Lihatlah semua konektor serta ujung kabel. . Setelah kontaminasi kotor dibersihkan, gunakan alkohol isopropil 90%+ dan bersihkan bagian-bagian Anda lagi. Untuk pembersihan yang benar, gunakan [panduan|5825|panduan ini.] Ini ditulis untuk Apple iPhone 3G tetapi semua langkah masih relevan dengan ponsel Anda juga. Saya sangat menekankan pentingnya pembersihan yang baik, jadi lakukan berulang kali sambil mengganti alkohol setelah setiap pembersihan.
Yang penting di sini adalah pembersihan. Tentu saja yang terbaik adalah membersihkannya secara ultrasonik. Jangan lupa mengganti baterai. Ini adalah suatu keharusan dan bukan suatu pilihan. Ini akan gagal jika Anda tidak mengurusnya sekarang.
Setelah itu, pasang kembali ponsel Anda dan evaluasi kembali. Selama Anda belum membersihkan papan dan mengganti baterai, semuanya hanyalah tebakan. Ingatlah bahwa kerusakan akibat air adalah masalah yang paling sulit dipecahkan dan diperbaiki. Tidak masalah jika terkena selama 2 detik atau 2 jam, yang penting adalah di bagian mana air (partikulat) tersebut menyebabkan kerusakan.
Beritahu kami apa hasilnya. Jika Anda masih belum berhasil setelah dibersihkan, Anda perlu memeriksa papan sirkuit. Untuk itu Anda memerlukan alat khusus dan memiliki keterampilan membaca skema (jika tersedia) serta mengetahui cara menyolder komponen yang sangat kecil pada papan yang padat penduduknya.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
