Zum Hauptinhalt wechseln
Repair guides and support for Kenmore washing machines.
20 Fragen Alle anzeigen
F35 code on Kenmore Elite. Washer
Washer popped an f35 code yesterday, took the pressure switch off, blew thru the long tube and sprayed some contact cleaner thru the short line on the switch. Reassembled and tried to run a clean cycle but after a minute the SUD error pops up. Any suggestions besides buying another switch?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
This question was migrated from https://meta.ifixit.com/Answers.
von
Einen Kommentar hinzufügen
1 Antwort
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
MCap wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 20
