Zum Hauptinhalt wechseln
Released in January 2018, the ThinkPad T480s is a slim version of the T480 with the traditional trackpoint and three-button trackpad.
11 Fragen Alle anzeigen
Will a Touchpad Replacement Fix My Floating Cursor?
I often have problems with my cursor floating away either up or down. I've confirmed that it is a hardware issue by watching it happen in the UEFI firmware.
In my research, people have seemed to suggest that it has to do with humiditiy. Would a touchpad replacement help in this regard? I'm sure that there's no liquid inside, though I suspect the previous owner might have spilled something on the laptop previously and now there is a residue that acts up now and again.
The problem seems to come and go.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
It could be the touchpad, but there's a chance it could also be the little red "Trackpoint" in the center of the keyboard. The way the mouse is drifting instead of bouncing around defnitely seems more like a trackpoint problem. To confirm this, I'd disable the trackpoint in Device Manager. To do this, type Device Manager into the Start Menu. When it's open, go to the pointing devices section (I think). In that subcategory, you should find your trackpad and trackpoint. From there, double-click the trackpoint, then click disable device in the window that comes up. If the problem goes away, you know the trackpoint is at fault. If it isn't something you use much, you can keep it disabled. If the problem persists, you should start looking into a trackpad replacement.
If you have any more questions, just leave a comment.
Hope this helps!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
edisondotme wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 31
