Zum Hauptinhalt wechseln
Das Garmin Nüvi 200 ist ein Teil von Garmins 200er Familie von Navigationsgeräten. Es wurde im Mai 2007 veröffentlicht. Verkauft wurde es mit Karten für Deutschland, Österreich, Tschechien und der Schweiz. Wahlweise in silber oder pink zu haben.
How do you fix the on off button?
How do you fix the on off button of a garmin nuvi 200?
Ist dies eine gute Frage?
Bewertung 9
2 Kommentare
This sounds great if you have the right equipment to fix it however, if one doesn't then who can I take it to to fix the switch?
von
I need the button to turn it on and off where can I get one? The button came off and went down the defrost
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
To determine if your Nuvi's switch is broken with no other issues, please confirm the following:
1. Pressing the on/off switch has no effect and the switch feels mushy
when pressed - no soft click.
2. The unit powers up and operates normally when using the car adapter
or USB adapter and can be turned off by pressing the reset button.
If the above conditions appear to be the symptoms of your Nuvi 350,
then most likely, the on/off switch has broken off from the main printed circuit board. use these guides to help
It's very unlikely that the switch itself is bad. The life cycle of this switch is 250,000 cycles. For example, if you pressed it 20 times per day for an entire year, that would add up to 7,300 presses per year. Divide 250,000 cycles by 7,300 and it would take 34.25 years before the switch would fail. No doubt the switch will outlive the Nuvi itself.
Taking the Nuvi apart itself requires the right tools. The internal flex cables for the antenna, touch screen and LCD screen are delicate and can be torn easily if you're not careful. The antenna flex cable runs through the swivel antena shaft and is very delicate.
You will need a surface mount desoldering/soldering station with illuminated magnifier. A standard soldering iron is far too big to solder the leads and will overheat the solder pads, lifting them off the board. All work should also be performed with proper grounding to eliminate static charge issues. . use these guides to help be blessed..
War diese Antwort hilfreich?
Bewertung 1
mike, this depends on was is going on with the switch. It is just hold in by the two casing halves. So take a look at it by using these guides.
Bewertung 0
1 Kommentar:
What if the switch is missing? Can it be replaced and repair? Other than that being plugged in at home or in the car, both works fine with this Nuvi 265W model.
No way to control the off switch on from the screen like my ancient Nuvi 650?
If I can do that then I would be ok with the former. Thank you.
von
Thanks @randaleholland
its really helpful answer
Bewertung 0
Antwort hinzufügen
mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 7,318
