Zum Hauptinhalt wechseln
Apples Top-Smartphone für 2020. Das iPhone 12 Pro Max wurde am 13. Oktober angekündigt und am 13. November veröffentlicht. Es verfügt über ein 6,7-Zoll-OLED-Display, ein dreifaches Rückkamerasystem mit LiDAR und 5G-Konnektivität. Nachfolger des iPhone 11 Pro Max.
20 Fragen Alle anzeigen
Forgot to disconnect battery during screen replacement
I repaired the screen of a iphone 12 pro max, I forgot to unplug the battery and now it will not turn on whatsoever. No sign of life. Is there any solutions to this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
In cases where there are "no signs of life" I always try a few things.
  1. Connect to a computer. Is it detected in any way? Check File Explorer, Device manager or Disk manager on a Windows machine if it doesn't show in iTunes. Use Finder, Disk Utility, or System Info on a Mac. This could mean it IS just a display issue.
  2. Connect to a USB ammeter/multimeter. The amount of power the phone is consuming can tell you a lot. It is a way of getting a read on behavior based on
  3. Check with the old screen. It's possible the new screen is the issue. Or see if it powers on with no screen attached.
If it is truthfully not powering up, chances are the logic board was damaged during the repair. The battery remaining connected opens the possibility for circuits to be inadvertently bridged when power is running through them. This commonly happens when parts are connected or disconnected. Or if metal tools are used during the repair and it slips.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Turns out the phone's battery was just dead. How embarrassing
von
@kenny44422 Hey, I would take that as a win. Glad it was just that. :)
von
Antwort hinzufügen
Kenny wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 46
