Zum Hauptinhalt wechseln
ColorOs 13.1 Processor Dimensity 900 octer -core
How to unlock phone from Chinese to global
It might be the OS or some other issue but I bought a phone that said global but everything is in Chinese and my sim card doesn't work when I plug it in. Model is PFDM00, build is PFDM00_13.1.0 CN01, color OS is updated to the newest version and android version is 13. I have the LOLWR edition
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hi,
A few things come to mind here.
If everything is in Chinese then you must not have set the phone up, in this case you would need to factory reset the phone and do the setup from the beginning.
Once you have set the phone up you can try your SIM, if the issue persists then the device may be locked to another service provider or your SIM may need a clean/check for oxidation if it’s an older SIM.
One other option would be to obtain an e-SIM if the device is unlocked.
The other thing is if the phone was a demo phone, it won’t have an IMEI associated with it, so you’ll never get a SIM or e-SIM to work.
This leads us to the option of returning the the device to the seller if they didn’t advise you of the phone being a demo phone that would not function with a SIM.
It would be nice if reset & provider lock is off and you are able to resolve with the reset.
Hope this helps
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I have the phone set up and I have IMEI but some apps and settings are in Chinese like the users manual even though I changed the device language to English in the settings.
von
Ahh,
Okay, I’ve read in the past that this can occur when switching from Chinese to English where some apps/documentation retains Chinese language.
Not sure if you would be game enough to reflash the phone with English global firmware, or if this would cause any problems.
But if you do a search on android authority’s website or xda’s website you may find some answers.
von
Antwort hinzufügen
Jffsniper11 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 109
Insgesamt: 228
