Mengapa ketika saya telepon layar hp mati
Mengapa layar HP saya mati ketika di buat telepon
Ist dies eine gute Frage?
hai, berikut informasi yang dapat Anda ikuti untuk melihat apakah Anda dapat memahami dan memperbaiki masalah tersebut. Anda mungkin harus menggunakan Google Translate.
https://www.geekinstructor.com/fix-scree...
semoga ini membantu
War diese Antwort hilfreich?
semoga ini membantu
hi, here is information you can follow to see if you can understand and fix problem. You may have to use google translate.
There are several steps to try that may fix your issue.
hope this helps
Proximity sensor issue.
Yakınlık sensörü sorunu umarım yardımcı olur, ayarı değiştirmek için ekrandaki okları takip edin.
https://youtu.be/eaVJUUpJ7UY?si=3A3_gdRb...
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 101
