Zum Hauptinhalt wechseln
7.1 megapixel camera by Canon, model SD750.
9 Fragen Alle anzeigen
new battery but screen black
when i turn the camera on the lens comes out but the screen stays black brand new battery fully charged
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Black screen is caused by a defective high intensity LED strip in the display backlight unit. When these fail you need to replace the backlight assembly
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
ric, try to hold down the menu key, turning it on and off and resetting the menu options. "Press the "Menu" button. Press the right arrow once to highlight the "Setup" menu. Press the down arrow five times to select "Reset All." Press the "Set" button. Press the right arrow button once to select "OK." Press "Set." from here.
If that does not work,check the flex connector on your LCD. Here is the guide for the LCD screen. You may have to replace the LCD. Hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
ric wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 7,644
