Zum Hauptinhalt wechseln
Apple's iBook Laptops waren für Endbenutzer und Bildungsmärkte gedacht. Die iBook-Reihe besteht aus dem iBook G3 Clamshell, G3 12-Zoll, G3 14-Zoll, G4 12-Zoll und G4 14-Zoll.
832 Fragen Alle anzeigen
Changing parts from one to another?
Hello, I wonder about the possibilities to use parts from iBook 12 inch LCD on the models G3 and G4. Parts as hard drive, battery, keyboard and well there must be more parts changeable? I'm thinking about buying used parts!
Thankful for answers.
Dick.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The LCD panel (But not the assembly) can be used in either computer, the batteries are also cross compatible, As is the hard drive, Keyboard, And charger. The logic boards, RAM, and Optical drives however, are not interchangeable.
War diese Antwort hilfreich?
Bewertung 3
Hilfreichste Antwort
These parts can be swapped between the 12" iBook G3 and the G4
SCREEN ASSY:
- LCD panel
- front bezel (inscription wont match)
- hinges
- back cover (with Apple logo) color wont match
- inverter board
- display latch mechanism
NB: cables CAN'T be swapped (connectors wont match on logic board).
Other compatibles parts:
- keyboard (please read rj713 comment)
- battery (color wont match)
- AC adapter
- hard drive (IDE 2'5" HD)
- bottom case screws and rubber feet (color wont match)
All other parts are model specific and can't be swapped:
- ram
- optical drive
- top case
- airport card
- logic board
- heat sink
- internal metal frame
- DC in board
- HD & optical drive cables
- fan
- etc.
Bewertung 4
3 Kommentare:
IIRC some keyboards won't work on some upper cases of the same model because of a groove in the top case is required for a proper fit. Ralph
von
thanks rj713, I edited my answer.
von
Thank you. Nice to know.
Dick.
von
Antwort hinzufügen
Dick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 951
