Zum Hauptinhalt wechseln
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
Release foot brake engine dies.
Release foot brake engine dies. New seat switch installed correctly but problem did not go away
Update (09/08/24)
Need help. Rlease brake pedal engine dies. Replaced switch
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@gmillioni what is the exact make and model for your mower?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The seat switch is not the problem.
There is a switch above the brake linkage underneath and to the rear of the engine.
The actual switch is on the right side, underneath the fuel tank.
Grass clippings and dust tends to build up around the electrical connector, and if the mower is out in the rain, or you wash the mower, the water tends to short out the connections.
The switch may not be bad (mine was OK), but the grass mat that has collected has to be removed, and the connector removed and blown out with air, or whatever.
(This same condition also causes the mower to stop moving while the engine is already running)
I guess it depends upon which connections are shorting on the switch.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Gmillioni wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 19
