Zum Hauptinhalt wechseln
Modell A1311 / Mitte 2010 / 3,06 & 3,2 GHz Core i3 oder 3,6 GHz Core i5 Prozessor
2010 iMac LCD temp sensor cable
I have a couple of questions…
1. Will an LCD temp sensor cable from a 27” iMac work in a 21.5” iMac?
2. How would I remove the old one from the back of the LCD panel  and how would I go about replacing it?
3. The reason I asked the 1st question is because I am having difficulty finding one that will fit a 2010 21.5” iMac.
LCD temp sensor cables for the 2010 27” iMac are far easier to find. Any help and or suggestions in locating a cable the 3010 21.5” iMac, if the answer to my 1st question is “NO”.
Any help in finding a cable that will work would be greatly appreciated! 😎
Thanks in advance
Joe
Update (09/30/24)
This is how the cable got “damaged’ and a picture of it.
One of the wires on the cable came loose when I was trying to disconnect it from the board and needs to be  soldered back on. I am thinking it would be an easier ti replace the cable with a “new” (undamaged) cable
u I think it would be “easier” to remove the 4 cablesthat I had to disconnect in order to remove the LCD from the back of it then install them into the boats 1st then the back of the LCD.
I am not sure how the LCD temp sensor cable attaches to board. I was having a difficult time trying to get the cable reinstalled into the board. That is why I was considering doing it this way
The reason I removed the LCD panel was because I want to replace the hard drive with an SSD.
I do not have a good way to magnify it and need better lighting in order to reinstall this cable.
Thanks
Joe
Update (10/01/24)
I finally have one coming… but I am not sure how it installs on to the back of the LCD.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Can you post a picture or two of the cable from your system so we are sure which cable. Can you also tell us how it failed.
von
Einen Kommentar hinzufügen
1 Antwort
Sorry to say the sensor is not available as a part on its own any longer, the best you can do is get a junker display and salvage it from it. Here’s a fairly cheap display iMac 21.5" LCD Panel, LED-Backlit (10) : Grade-C from TheBookYard in the UK. If you contact them directly maybe they can send you the sensor cable on its own.
Update (10/01/24)
If you look at the image on the display it’s just glued to the back side. Double stick Tesa page is all I would use.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Joe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 24
Insgesamt: 274
