Zum Hauptinhalt wechseln
Das iPhone 13 mini ist eine kleinere Version des iPhone 13 von Apple und das zweite mini iPhone. Es wurde am 24. September 2021 veröffentlicht. Es verfügt über ein 5,4" OLED, einen A15 Bionic-Prozessor und ein Zwei‑Kamera-System.
Unable to finish battery repair with Repair Assistant
I have managed to replace the battery in my iPhone 13 mini successfully. The phone seems to work fine but the "Finish repair & restart" item is not showing up in the Settings app. It showed at first but when I tried using it it failed (something about failing to contact the server). I retried a couple more times, but the item just disappeared (nor is it available in Settings > General > About > Parts & Service History, it shows that my battery is an "unknown part"). I tried restarting, making sure my phone is connected to WiFi, disabling PiHole, nothing helped.
I hear the repair assistant is still new and very flaky, but I was wondering if I can still finish the repair. Also, is there a point in contacting Apple support about this?
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
1 Antwort
Hi Andrii,
did you try this:
Phone is off
While holding down both the volume up and volume down buttons, plug the iPhone into a power adapter until the Apple logo appears
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Hi Michael! Thanks for the tip. I managed to boot my iPhone into Repair Assistant by following the steps you suggested, but when I tried to finish the repair I got an error message: "Unable to Configure Battery. This part could not be configured because it is not a genuine Apple part or may not be functioning correctly. Check that the part is properly connected and try again. For more information, refer to the iPhone service manual for this device. You can continue using your iPhone, but may experience unexpected behavior. View all of your repair details in the Parts & Service History in Settings."
von
Antwort hinzufügen
Andrii wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 95
Insgesamt: 632
