@tanjachristin really not to bad. I just followed the traces and marked where you could apply jumpers to. That would allow you to resolder a connector. Now, we can't see your old connector to well but it might just be possible to fit it back on. For the left and right ground (large solder pads), just use a scalpel or similar tool and gently remove the green layer until you see the copper layer coming through. You can connect the ground to that.
As for the who can do it, that gets tricky. Anybody that does motherboard repairs can most certainly do it. Since I do not know what the hourly rates are in your area, I can not speak for how much it costs. Luckily you live in a pretty well populated are. I would suggest you check with either an Electrical Engineering or Computer Engineering program at one of your local universities or even a technical school. Over here, those programs love a good challenge and like to repair real world devices.
Should that not work I'd try one of the many RC clubs in your area. Something like this one or the one on here as well as many others. Those folks do some pretty amazing stuff and will most likely know someone who can/will help.
The best place to get some help is always a Repair Cafe. there you will find some amazing people that have a great network to anything repair related. I am certain they will help you out. Just check on here or Google Repair Cafe for your specific area.
Again, the repair is not complicated just not lucrative for a repairer since it is labor intensive and could cost you more than a new circuit board, which you do not need.
Repair is War on Entropy!
Translation
@tanjachristin , wirklich nicht zu schlecht. Ich bin einfach den Spuren gefolgt und habe markiert, wo man Brücken einsetzen könnte. So könntest du einen Anschluss neu löten. Wir können deinen alten Anschluss nicht gut erkennen, aber es könnte möglich sein, ihn wieder anzubringen. Für die linke und rechte Erdung (große Lötpads) verwendest du einfach ein Skalpell oder ein ähnliches Werkzeug und entfernst vorsichtig die grüne Schicht, bis die Kupferschicht zum Vorschein kommt. Daran kannst du die Erdung anschließen.
Was die Frage betrifft, wer das machen kann, wird es knifflig. Jeder, der Motherboard-Reparaturen durchführt, kann es mit Sicherheit. Da ich nicht weiß, wie hoch die Stundensätze in deiner Gegend sind, kann ich nicht sagen, wie viel es kostet. Zum Glück lebst du in einer ziemlich dicht besiedelten Gegend. Ich würde vorschlagen, dass du dich entweder an einen Studiengang für Elektrotechnik oder Technische Informatik an einer deiner örtlichen Universitäten oder sogar an eine technische Schule wendest. Hier lieben diese Programme eine gute Herausforderung und reparieren gerne Geräte aus der realen Welt.
Sollte das nicht funktionieren, würde ich es bei einem der vielen RC-Clubs in deiner Gegend versuchen. Zum Beispiel dieser oder dieser oder auch viele andere. Diese Leute machen ziemlich beeindruckende Sachen und kennen höchstwahrscheinlich jemanden, der helfen kann/wird.
Der beste Ort, um Hilfe zu bekommen, ist immer ein Repair Cafe. Dort findest du großartige Menschen, die über ein hervorragendes Netzwerk für alles verfügen, was mit Reparaturen zu tun hat. Ich bin sicher, dass sie dir helfen werden. Schau einfach on here oder Google Repair Cafe für dein spezifisches Gebiet.
Noch einmal: Dies Reparatur ist nicht kompliziert, aber für einen Reparateur nicht lukrativ, da sie arbeitsintensiv ist und mehr kosten könnte als eine neue Platine, die du nicht brauchst.
Reparieren ist Krieg gegen die Entropie!
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
