Zum Hauptinhalt wechseln
Veröffentlicht Januar 2015, Der XPS 13 Laptop ist ein Konkurrent des MacBook Air, mit einem randlosen "infinity" Bildschirm mit Touchscreen Option.
20 Fragen Alle anzeigen
M2 Screws for battery replacement
Hi - I want to replace the battery in my Dell XPS13 and need the three M2 x 2 screws to hold the battery in (managed to lose them). I can get M2 x 2.5 but can't find anyone who stocks M2 x 2. Can anyone suggest a source OR can let me know if I can get away with M2 x 2.5 - I suspect they may be too proud. Thanks
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi @mick26213
Please confirm the model number of the laptop?
Looking at p.18 of the owner manual for the model you selected, it shows that there are 4 screws securing the battery.
How did you verify the length of the screws and what is the screw head diameter, so that it will sit in the battery screw hole? Found a few suppliers for M2 x 2mm but they had different cap (screwhead) sizes, e.g. M2 x 2mm x 6mm (cap) which mightn't work if it is too big
von
@jayeff Thanks for getting back - it's the 9343/9350.
iFixit had the M1.6 x 4 fourth one but not the M2 x 2s. The length is in the ifixit repair guide and marked on the old battery itself. I've measured the cap size because they are countersunk in the battery and it is 6mm. So grateful if you can share a possible supplier.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @mick26213
Might depend on your location but here's the supplier I found.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Mick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 32
