All the necessary parameters are not obvious by your pictures or description.
What is obvious:
Snap in, SPDT, 16A @ 125V, quick connect 0.250 terminals
What is not obvious, and important:
Panel cutout dimensions
If the sw has a center off position
If it is lighted.
THIS page has all of what I perceive to be a snap in, SPDT, 16A, 125V, with quick connect 0.25 terminals. You can change the filters to see other switches. All of these require a rectangular - 28.58mm x 13.97mm cutout.
You might also search AliEpress to find a match.
NOTE: most of the switches with quick connect spade lugs that burn like that are caused by loose spade lugs. That heats up the sw terminal and melts the plastic. Make sure they are tight by squeezing the wire terminal with pliers, Gently. You don't want them impossible to put on.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
