Zum Hauptinhalt wechseln
Die Xbox Series X ist die 4K Gaming-Konsole der nächsten Generation von Microsoft. Die Xbox Series X wurde mit der Xbox Series S am 10. November 2020 auf den Markt gebracht.
20 Fragen Alle anzeigen
Xbox Series X PSU Compatibility 12 vs 14 digit serial
I need to replace the PSU in my Xbox Series X the 2020 release (12 digit SN), it looks like the latest XBX 2024 revision (14 digit SN) has a new Genuine PSU model compared to the 1920 model, are these two compatible with each other?
Newest revision: Microsoft Xbox Series X Disk Drive Model 1882 (14 digit serial number) Power Supply - Genuine
Older revision: Xbox Series X Power Supply
Replace a power supply module compatible with the Xbox Series X video game console model RRT-00010 and RRT-00013. Fix issues like a malfunctioning or burned out power supply. Bild
Produkt
$69.99
Replace a power supply module compatible with Xbox Series X Disk Drive model 1882 14 digit serial number gaming consoles. Fix issues like a malfunctioning or burned out power supply. Bild
Produkt
$86.99
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi Kevin!
Nope, they are not (If I need to believe Microsoft). You need the correct model to let it work. So, please check what model came out yours and then order the correct model you need.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I installed it and seems to be working fine for the past week. Not sure if it's officially supported but unofficially seems to work fine
von
Ah, good to hear that it does work! Officially, it shouldn't, but glad that it is running without issues so far! Will update on this.
von
Antwort hinzufügen
Kevin Stichter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 83
