Zum Hauptinhalt wechseln
How do I boot into bios
Every google result tells me how to boot into bios on a normal laptop, with function keys. This laptop doesn't have those.
An answer would be appreciated. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @jeff___
Chromebooks don't have a BIOS like other PCs as they use the Chrome OS to function
Here's a link that describes it better than I can.
War diese Antwort hilfreich?
Bewertung 2
12 Kommentare:
Hi Jayeff,
Thank you for your response.
Is there an equivalent that is available on Chrome OS?
Thanks
(W name btw)
von
@jeff___
You need to have a laptop that is working to access the BIOS info in Chrome OS.
Here's a link
von
I do have one. The post that you attached does not mention anything about using another device. How would I use another device to get the BIOS of my Chromebook?
Thanks.
@jayeff
von
@jeff___
I meant that to access the BIOS in the laptop, it needs to be working i.e. able to be turned on and the OS loaded OK etc.
My comment was based on that you asked another question, previous to this one, on the same day, for the same model, where you said that it will not boot.
von
7 weitere Kommentare anzeigen
Antwort hinzufügen
jeff wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 17
Insgesamt: 101
