Zum Hauptinhalt wechseln
Das Apple iPhone SE der 3. Generation ist mit einem A15-Prozessor und einem 4,7 Zoll-LCD-Display ausgestattet.
20 Fragen Alle anzeigen
Faulty battery or Apple anti-repair anti-right to repair?
Just did a battery replacement for somebody last night phone said 0% when I plugged it in. Used an iFixit battery. He left this morning and shortly after unplugging the phone it died plugged it back in works unplug it it dies. Battery is not charging, is this a defective battery or is this Apple anti-repair since they sell the same battery for 5 dollars less? (after you find the super secret code and return the old one, if not it's 75 $ just to place the order). It did give the battery warning just like the previous model SE, unlike the previous model it never charged at all. I will find out more when I swap with a genuine battery. This guy seems to be plagued with phone problems or is it me, SE2020 Battery, screen, screen, SE2022 replacement phone, battery, now another replacement battery. On the upside I'm getting really good at doing phone repair.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
If your iPhone shows 0% battery even after plugging it in after a battery replacement, it likely indicates a problem with the connection between the new battery and the phone's charging circuitry, potentially due to a faulty battery, damaged charging port, or a loose connection within the phone itself; check the charging port for debris, try a different charging cable, and if the issue persists, consider taking your phone to an Apple authorized repair center to have the connection inspected and potentially re-soldered.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Thanks. The client is going to attempt the Apple store but it is unlikely as they're playing the third-party repair and liability card, so they probably won't touch it if it has a third-party battery. They (I believe over the phone) literally said if it's not a genuine battery things could be damaged or missing and that they wouldn't be able to repair it. Considering the 5 to 7 day shipping from the authorized parts center I will probably be reinstalling the old battery tomorrow.
It sounds like it's holding a charge for a brief few minutes well unplugged so it is functioning unplugged but it's not charging and I believe it's saying not charging in settings.
von
Check the area arround the batteryconnector , you might knock a small component of the logic board.
von
Antwort hinzufügen
imark7777777 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 36
