Zum Hauptinhalt wechseln
Eine preisgünstigere Version der Nintendo Switch Spielkonsole als rein tragbare Konsole, mit eingebauten Joy-Con Controllern und etwas kleinerem Bildschirm. Erschienen am 20. September 2019.
20 Fragen Alle anzeigen
Right thumbstick still drifting after replacement.
So I replaced the right thumbstick due to extreme upward drift. The new one keeps having the same issue. I've tried 3 different sticks and they have the same issue. Could there be something else causing this. Calibration was done already.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hi Alex!
Okay, so only the right joystick is having issues at the moment? Can you share some pictures with us? Everyone is up to date I presume? Could still be motherboard related.
von
Einen Kommentar hinzufügen
1 Antwort
Try cleaning the ZIF connector and check the motherboard for corrosion. Could be those problems, since I’ve encountered them myself. Had a piece of goo or whatever it is stuck in the ZIF connector and caused my joystick to drift downwards even though I calibrated it. The solder might have disconnected for some reasons as well, so I would suggest you to check the whole area for any kind of damage.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Alex Schneider wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 12
