Zum Hauptinhalt wechseln
My battery has been got complaint and I removed it.
My laps battery got complaint and I removed it. and I used my lap for some days without battery just plugged in. And after some days my lap showing CMOS error 504. And showing bios update,finishes it, restarts, repeating the same for few days.My laptop model number is hp du1052tu.with Intel Pentium gold 6405 processor.what should I do?plz help me to make my laps problem resolved.Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi @cyberbeastyt
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
von
@jayeff bro it's hp du1052tu
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Without the exact model number I can't say for sure, but my initial impression is that your laptop may not have a CMOS battery; instead it relies on the main battery to maintain the CMOS settings. If that's the case, you are going to lose your CMOS settings every time you unplug the computer since you've removed the battery.
Be sure to edit your question and add your model number so we can verify that supposition, but in the meantime here's someone on the HP forum who had a similar problem and got the following answer.
HP 15dw series laptop has a CMOS error, there's no CMOS batt... - HP Support Community - 9272779
‎01-03-2025 08:04 AM
Follow the steps below to reset computer CMOS data.
1. Turn off the computer.
2. Press and hold the Windows and the V keys.
3. While still pressing those keys, press and hold down the Power button on the computer for 2-3 seconds.
4. Release all the keys.
5. At the completion of a successful CMOS reset, a message showing CMOS Reset (502) will be displayed.
6. Restart the computer.
7. Press F10 to get in to bios. Check Date and time.
8. Press F9 to set bios defaults. Ensure secure boot is enabled.
9. save setting when you exit
If you do not see that 502 message then :
  • Turn on the computer by holding the power button down for 20 full seconds then release.
  • Press the Power button one more time (if necessary) to start the computer.
  • Tap the ESC key about once a second after you see the LEDs on the keyboard flash.
  • Do steps 7-9 above
Update (02/20/25)
Okay, with the model number you provided, I was able to locate the service manual for your laptop.
Maintenance and Service Guide HP 15 Laptop PC
What I found is that your laptop does not have a CMOS battery to maintain the BIOS settings; rather it relies on the main battery to keep that information in memory. However, since you've removed the battery, the only thing that can hold the memory from disappearing is the power cord being plugged in. As such, every time you unplug the computer, you lose the CMOS memory and you are going to get that 504 Reset Occurred error. You will then have to reset the CMOS data, which will remain until you unplug the computer again.
There's really only one way to fix the problem, and that's to replace the battery. After that it will be able to maintain the CMOS memory and you will rarely see the error ever again. The service guide I linked to has instructions for replacing the battery.
War diese Antwort hilfreich?
Bewertung 0
13 Kommentare:
It's shown CMOS 504 reset occurred.but it's showing bios update again.what should I do
von
@dadibrokit thx bro I tried to open bios settings by clicking f10 but it didn't.so should I change the CMOS battery too.is there any other way to fix by myself.and thx for helping bro.
von
@cyberbeastyt
Try pressing Esc and then F10 to enter BIOS on startup
von
@jayeff Bro it's ain't working.its showing bios update about of 4000 something files update finishes it and does again but speedily.turns off.shows windows CMOS RESET occurred 504.the continues to bios update and repeats the same.and show bios recovery 500 occurred.enter to continue.tgen continues.and repeats the same.and not even showing hp logo though.Am i cooked.bruther.is there any way to attach file so I can share my problem correctly with a video.
von
@cyberbeastyt
If you haven't already done so, you should change the battery before trying the BIOS update
You need to have a main battery installed. You may have to get a new one before attempting the BIOS update. It's all related. Everything needs to be there for things to work.
von
8 weitere Kommentare anzeigen
Antwort hinzufügen
Cyber beast YT wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 71
