Zum Hauptinhalt wechseln
Herausgegeben im Oktober 2008 / 2,4, 2,53, 2,66, 2,8 oder 2,93 GHz Core 2 Duo-Prozessor
Can I replace just the keyboard?
My MBPro A1286 Intel Core Duo Model 5,1 got wet last weekend. Now several keys don't work. I did some research and found out that most parts providers offer only replacing the top case along with the keyboard. (pretty expensive!) Then I found this site Link text that offers Just the keyboard (much better, money-wise) Seems to good to be true...Is this doable? and how come you don't have a guide here for this procedure? (did a search with my model number and the closest I got was to a top case replacement guide) Thank you!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
hi , yes its totally possible to change only the keyboard but its much difficult and take many time.
No guide on internet for replace only keyboard if i have time next week i will make a guide for you
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Yes, you can replace just the keyboard.
You can use this guide as an example:
Replacing keyboard on MacBook Pro 15" (Mid 2010)
The guide is for a different model but should be very similar.
Bewertung 2
Antwort hinzufügen
gilarturo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 3,546
