Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
106 Fragen Alle anzeigen
Which parts are required to complete a screen replacement
I have replaced the digitizer on a few iPad 2nd gens. I typically replace the middle frame bezel every time I replace the digitizer. I haven't been able to find replacement middle frame bezels for the new iPad. I was wondering if the iPad 2 bezel would fit, since the old one typically gets some minor damage during removal of the digitizer. Also, is the adhesive similar between the generations?
-Thanks,
jwesleym
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
I just did an iPad 3 Screen replacement,
For the most part, the replacement is about the same - and most of the adhesive is the same too (there are a couple of bits different, but nothing that should affect anything). The part I ordered came with the plastic bezel, I do not know how similar it is to the iPad 2 as I have never replaced the bezel with the screen in the iPad 2.
-David
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
How much does the screen cost?
von
I would also recommend foam tape gasket around the LCD. It gets torn when opened. Dust will enter the screen
Bewertung 0
I use the old bezel too (only if it is in Good condition).
And you, you too or not?
Thanks, Mauro Ju Macniaco
Bewertung 0
Antwort hinzufügen
jwesleym wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 3,107
