Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
After replacing my screen, I only have dark blue backlight.
Hi,
Today i replaced the screen on my iPhone 4, i put the phone back together and it powered on fine, and the new screen worked perfectly.
I then noticed that the sim tray was not sitting flush with the phone so i took it apart again and fixed this issue.
When i put the phone back together again, the screen only displayed a dark blue screen.
I am able to access 'Voice Control' so im pretty sure the phone is in good working order apart from the blue screen.
Does anybody have any idea of what i have done wrong here, or have any ideas of what may be wrong?
Many thanks
Charlie
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
no.1 thing is to undo it all and then redo..maybe something has come loose? no.2 if you only have blue light then it sounds like the flex is damaged..most screen issues that can be fixed with hard reset are white screen or black screen. Try reseating the flex and see what happens. (also check the frame screws aren't on too tight?)
von
Please help! I'm having the same issue
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If you having the same problem we sometimes have when testing LCDs, I think this may work. Try to reset the phone by pressing the home button and the mute button for about 5-10 seconds. If that doesn't work, disconnect the battery connector from the logic board and plug it back in and turn on the phone.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
I have tried hard restetting the phone already and have disconnected the battery and reconnected. still no luck.
von
This is pry damage near LCD/digitizer connectors.
Find the missing/damaged component to confirm, then send out for board-level repair
Bewertung 1
Antwort hinzufügen
Charlie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 4,477
