My daughter dropped her ds on the floor and now it will turn on and then immediately off. I tried charging the battery and even replacing it with another good battery from another DS we have, but still the same problem. The right most light turns green when powered on for about 1 second but then shuts off
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
Unfortunately it could be a variety of problems. Fortunately they all have workable solutions.
Perhaps the easiest problem to fix would be if, when it was dropped, one of the cables became loose or disconnected. In that case all it would take to fix it would be to open the DS up and ensure all the cables are properly seated.
A more difficult one to address is it is possible that when it was dropped a component was knocked off the main board. And it is quite common for an inductor to get knocked loose in a drop, located near the power switch. But it is an easy solder if you happen to work with electronics.
If you want to further diagnose the issue I'd recommend using the following guides to disassemble the device and check for possible damage:
6 Kommentare:
+ damage to the hinge damages the cable connecting the top LCD and can give the turn on turn off issue.
I had this issue. The cable for one of the screens came unseated, and when powering on, the DS lite would flash green for a second before failing to power on.
The screen cables need to go ALL the way in. It’s a little farther than I thought.
6 Kommentare
trun on problams
von yams computer
plz talk to me
von yams computer
Ha (that happiness to me to)I don't know how to fix it
von Jacob
How to fix a DS lite that turns on and instantly off
von Jacob
I have this issue after I rehoused the system. the botton screen turns on, and the blue light comes on, but then shuts off after a second.
von Sam Gray (darkling898)
1 weiteren Kommentar anzeigen
