Which model Macbook do you have? The first step is to try and reset your SMC, you can do so by following the directions below;
Resetting the SMC on Mac portables with a battery you can remove
Shut down the computer.
Disconnect the MagSafe power adapter from the computer, if it's connected.
Remove the battery.
Press and hold the power button for 5 seconds.
Release the power button.
Reconnect the battery and MagSafe power adapter.
Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
Release all the keys and the power button at the same time.
Note: The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
If this does not resolve the issue then the problem is most likely hardware related. The resolution will depend on which model you have. Earlier Macbook models have an inverter inder the clutch cover which converts the power for the backlight, if this fails then you will not see any light but you can still see the `screen` when a light is shining on the screen. If you get the light to come on by moving the screen around then this could possibly be resolved by reseating the cable. If your model of macbook is newer then the screen will be LED and no longer have an inverter. This could then be a faulty Logicboard or screen.
Do you know which Macbook you have?
Regards,
Wes
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare
I have the same problem. Have a macbook pro retina 13-in mod 2014. Tried all the resets and command option pr and sleep then turn off and on again. Nothing worked. I can see the screen on an external monitor or with flashlight.
von Susan
Susan, I suggest you start a new question as this one was from 2012 on a much older machine. Your model will have entirely different solutions.
von mayer
