Why wont my jeep start
points and condenser have been replaced the coil too but when turning over there iis no fire power to the coil
Ist dies eine gute Frage?
Susan Luntsford, you did not tell us if it is stock or if it is a mod jeep. Engine Size and mods are important since it does make a difference. If you have no power to the coil, check your ignition switch. Make sure the switch close the circuit to the ignition coil. Check the wiring from the positive terminal of the battery to the switch, make sure it is connected and not shortened out. If it worked before, but stopped working since you replaced the parts, double check your work.
War diese Antwort hilfreich?
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 57
Insgesamt: 3,582
