Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
Frage geschlossen
No power after screen replacement.
Hey Guys Jesse here with iGadget Repair Center.
I have prob done about over 100 ipod touch 4th gen screen replacements and this has happened twice. I open up the device and i'm always very careful with the power flex. Removed the old screen and replaced it with a new one.. Now ipod will not power on,, computer wont recognized it, itunes nothing.... I made sure the replacement screen wasn't defective.. But the darn Ipod will not power! any advice guys? thanks a mil!
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Same thing happened with me...
von
I found out why. The camera was damaged.
von
I have the same problem and none of the answers are working.
von
Einen Kommentar hinzufügen
10 Antworten
Same thing happened with me and it was my first ever iPod Touch 4th Gen fix! So I panicked! lol. But it turned out after disconnecting and reconnecting the digitizer a few times I got it; it was just a faulty connection (because you know how hard connecting that bloody digitizer is).
I also plugged it into the computer as opposed to just a wall charger. I got the white screen, which fixed itself with a hard reset (power + home button until the apple symbol appears).
It took me like 5 hours of just fiddling and tweaking to get it all good again ... it was torture!
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
My computer wouldn't recognise it until I had made absolutely sure that the digitizer was connected properly, by the way.
von
I finally got mine to SOMEWHAT work. After disconnecting the new digitizer and re-installing the old one it seemed to work just fine (to my relief lol) so I then un-installed the cracked digitizer again and re-installed the new one and still same problem, no power and wouldnt be recognized by the computer. So I started messing around with the connections and finally got it to display a white screen and when plugged into the wall charger it would make a beep. Tried a hard reset because I've had the white screen issue before and solved it with a hard reset. Upon trying the hard reset the white screen would go black after about 10 seconds, so i'm assuming the iPod was restarting, because during this time it wouldnt respond to me pressing the home button for around 10-15 seconds (boot time?) then after the 10-15 seconds when I press the home button I just got the white screen again. I'm assuming I got a bad LCD since I know the iPod is still good after re-installing the old screen. So I am going to send back the faulty screen and hope for a better result with the next screen. It is now recognized by iTunes also. But still just displaying a white screen. If anyone has any suggestions that might work before I try sending this screen back I'd appreciate it.
Bewertung 0
@genesis rubio. I'm almost positive you have a defective display. Same thing happened to me and i connected the old screen again and it worked fine. Sent the display back that was giving me the white screen and they replaced it with a different display and it worked like a charm. I would suggest exchanging it for a different one and i would be willing to bet that works.
Bewertung 0
Try hard resetting it. For some reason my ipod touch went into DFU mode
Bewertung 0
hey if you hold the home and power off and volume up button until it shows the apple logo that will fix the white screen issue thats all i can do to help
Bewertung 0
i changed the LCD screen on my ipod but when i tried to charge it so it could turn on it would just keep turnin on and off and the screen said it wasnt charging. What do i do to fix it ?
Bewertung 0
Try to remove and solder again the battery..
Bewertung 0
Turn off your ipod, ect before any opening
Bewertung 0
there is kind of like a metal thing on top of ipod4 that was taken from old one that connects to a spring exactly beside back camera when they connect they dont display white anymore only if it has the right amount of force pushed to it try this out and find a way to stick them together good hope this helps
Bewertung 0
For me I just installed it waited a whole day, then I plugged it into the charger and the screen came on.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 16,177
