Zum Hauptinhalt wechseln
Reparaturanleitungen, Informationen zur Demontage und Fehlerdiagnose für den Mac mini (2020) mit Apple M1 Chip. Identifizierbar durch die Modellnummer A2348.
Bypass Activation Lock by replacing Logic Board?
I recently made the dumb decision of buying a Mac Mini that is locked. I was not well informed when it comes to Macs and thought I could reset it easily like windows, that is not the case.
Would replacing the Logic Board of the Mac Mini A2348 bypass the Activation Lock? I keep finding contradicting answers so any help on the matter would be greatly appreciated!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
If you can prove ownership, an Apple store should be able to help you. They require that because it's to help fight with theft.
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
@rickwag unfortunately i bought this off someone who got it at a thrift store. Double L on my part. just wondering if changing the logic board would bypass the Activation Lock
von Teilen
Hey @romy_patino , if you replace the logic board you'll have a different computer so yes you'll bypass activation lock, but the new board is completely seperate from the locked one. Basically activation lock sits on the board so that computer with activation lock is now permanently locked & as far as i am aware you can't use any hardware off that board except the micro components.
Hope this helps :). Let me know if it doesn't make sense
von Teilen
@np_f1_2021
I’m not looking to reuse any components from the logic board with activation lock. I already spent $100 on the locked Mac off eBay, so at this point I’d just rather spend the $200 on a new board rather than $300 on another used Mac.
But just for clarification, if I replace the logic board I then shouldn’t have any activation lock since it’s essentially a different computer now?
Thanks for your help!
von Teilen
That's right, new logic board = new computer :)
von Teilen
Antwort hinzufügen
Romy Patino wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 35
Letzte 30 Tage: 135
Insgesamt: 1,818
