Zum Hauptinhalt wechseln
iRobot Roomba 5xx Series Battery Replacement
I want to replace the battery pack on an iRobot Roomba 500 series. How do I gain access to the battery pack already installed in the Roomba? I have seen photos of a battery pack purchased from batteryspace.com intended for the Roomba, but not photos showing how to access the battery compartment itself. Thanks, Bob Cochran
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I've got the URL for the manual for the Roomba for you. Scan down and you will find info on removing and replacing the battery. Ralph
http://www.irobot.com/uk/home_robots_faq...
War diese Antwort hilfreich?
Bewertung 2
Hi, before you go and buy a replacement battery, you might want to try to reset the Roomba first. The Roomba may be set in a state where it will only charge to a certain amount. Just follow the instructions indicated here to reset your Roomba.
http://www.eesolutions.ca/roomba_battery...
Bewertung 2
Antwort hinzufügen
cochranb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 8,438
