Zum Hauptinhalt wechseln
How to fix PS4 dualshock controller right joystick stick drift
The right stick when pressed down just moves the camera up when pressed to slide in a game like Fortnite and when aiming it's not stable and moves by itself in any direction so I constantly have to pull it back to track a player in a game
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
The Dualshock 4 controller uses potentiometers for sensing joystick positions. Since these are mechanical sensors, they wear down over time, usually within a year or two depending on usage.
Sometimes you're lucky and there's just some dust inside the potentiometer that you can remove with a blower, most more often than not you will have to purchase either a replacement joystick assembly, or new potentiometers, and perform some soldering in order to fix stick drift on these controllers.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Tshepang wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 29
Letzte 30 Tage: 124
Insgesamt: 818
