Zum Hauptinhalt wechseln
Turn 17 "screen into external monitor?
My computer died a horrific death (cider was involved), and I've salvaged the hard drive, and the other removable stuff, but what I really want to do is pull the screen out and turn it into a VGA or DVI external monitor. It could then be a very low power, small footprint wall-mountable device.
Any ideas as to how to build a VGA or DVI adaptor for it?
This is NOT a software question. It's a hardware/wiring question.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
3 Kommentare
When you change the question the answer does not fit. Please just add a comment to help clarify what you want.
von
Any success with this attempt. Even I am looking for the same solution. Kindly share in case if you have one.
von
Looking for the same solution....
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Here's how to do it: http://www.macupdate.com/info.php/id/229...
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
No, that's software. I want to physically wire the display to a vga port.
von
Ooh, close, but the apple laptop screen has a weird "apple created" plug that goes into the motherboard for video. That plug needs to be converted into a VGA or DVI plug.
von
Try this...
Reuse the flat LCD panel to a vga monitor
Bewertung 1
Antwort hinzufügen
deadtroll wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 13,799
