Zum Hauptinhalt wechseln
The Panasonic SA-UX100 (SC-UX100) is a mini Hi-Fi audio system released around early 2017. It delivers 300W (RMS) output through a 2-way speaker system, featuring a 13cm woofer and 5cm tweeter. Key features include Bluetooth, CD player, USB playback, and FM radio.
Why does the appliance not switch on
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@juniorkasabe you are not telling us what you have already checked. Make sure you have a good power cable and that your electrical outlet is working. If that checked out ok, you will need to check the fuse F1 on the power board for continuity.
Let us know if you have never done this or if you need help with that. Whatever you do, disconnect your device from the main power and do not touch components on the power board until you discharge the capacitors.
Here is the Panasonic SA UX100 Simplified SM for the schematics etc.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Junior Kasabe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 15
Insgesamt: 43
