Zum Hauptinhalt wechseln
The first Legacy was available at Japanese dealerships on February 1, 1989, with worldwide distribution starting in 1990.
Seized Left Rear Wheel
my L/R wheel is seized,is it the rear hub unit bearing?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
7 Kommentare
What is your definition of "seized"? what does it do and what does it not do? Did this just start? What type of transmission does it have?
von
wheel will not engage forward or reverse,just happened,auto transmittion
von
is it FWD or AWD?
von
Its All Wheel Drive
von
Same thing, check the brakes, see if you can release the brakes and if your wheel will turn. Possible seized bearing or seized rear differential :(
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Donna, if it is a FWD model, it is possible that your hub has seized up. Of course, the only way to really determine this is to, jack up the car, remove the wheel, and remove the rear brake. Possibly that your break is causing this too. Check to make sure that the brake shoes from the parking brake are properly releasing, and the the brake caliper is not seized.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Donna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,303
