Zum Hauptinhalt wechseln
Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 Fragen Alle anzeigen
Frage geschlossen
How can I recovery HDD information from a dead compaq presario V6000?
How can I recovery, "mainly" my outlook old emails and files in a HDD from this dead computer?
Computer was running a Windows XP and Office 2003, it doesn't start up any more, I get a message saying that Windows is corrupted and need the CD installation which I don't have any more.
If I remove the HDD can I read it and recovery with my MAC just connecting with and adapter to USB 2.0? I have a VMWare fusion running in my machine with windows 7 and Office 2011. If so, how is the procedure for that!
Somebody knows if is there any silicon enclosure that I can get and connect it?
The HDD model is: Momentus 5400-3, HP 418267-002
Thanks everybody!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It does not sound like your HDD is giving you errors, just your OS. I would the drive connected, boot from the optical drive with a Live Linux CD and copy the files needed. Just remember, since you are still without an OS, I would also consider to get a proper version of the OS of your choice, otherwise the computer will remain non-functional.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
"get a proper version of the OS of your choice, otherwise the computer will remain non-functional."
He could actually fix it easily.
This is a well-known problem, you can fix it by following this guide (not on ifixit this time ;) )
http://support.microsoft.com/kb/330184
von
@The tinker, that is correct. There are a few other ways of getting it done, most of them require access to the OS to incorporate those. However, I still advocate top get a backup of ones OS, and even if it is just for cases like this. Even the link that you provided requires the CD.....
von
You can easily recover:
-Download here ubuntu: http://www.ubuntu.com/download/desktop
-Burn it
-Insert the CD in your computer
-Boot it
-Click on try ubuntu without installing
-Click on the file manager
-Plug an external HDD or a usb key and copy the needed documents
Hope this helps you
Bewertung 1
3 Kommentare:
hi there,
didn't work!
I'm still getting the following message:
"Windows could not start because the following file is missing or corrupt:
<windows root>\system32\hal.dll.
Please re-install a copy of the above file."
von
It still is trying to boot from your HDD, you must set the boot order in your BIOS to CD first. Then you can boot from either your Windows CD or a Live Linux CD.
von
We can easily find it on internet: just type something like "download windows xp iso" and you'll get what you need.
von
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 583
