Zum Hauptinhalt wechseln
Anleitungen und Hilfe für verschiedene TV-Gerätehersteller und -typen.
9064 Fragen Alle anzeigen
Why does it shut off shortly after turning on?
When turning on the tv, it stays on for a short period of time, anywhere from 30 seconds to 5 mins. Just before it shuts down, it makes a buzzing/whizzing sound, then the screen shuts off, but you can still hear the audio for about 10 seconds, then it turns off completely. Once it turns off, the lights on the power button flash (Lamp, Timer & Stand By/Temp). I just replaced the bulb on it today, thinking that may have been it, but it is still doing the same thing. Any ideas?
EDIT: I decided to start looking over the boards to see if any thing looked fried, didn't see much on the boards, but when I got to the color wheel, I noticed the small piece of glass on the casing of the color wheel assembly was cracked. Not sure if that would cause the problem that I have or not, but im sure it can't be good. I spun the color wheel by hand, and it does sound like it may have something rubbing against each other while its spins. The plug to the magnetic board looks like it may have over heated as well.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
I've got the color wheel on order. Should be here by the end of this upcoming week. Hopefully that will fix the problem. I've looked over half of the boards, including the power supply, and it all looked pretty clean except for the one board on the color wheel which was mentioned on the first post. Will update once the wheel has arrived and I've had a chance to replace it.
von
I have faced the problem on sound becomes off after minutes run.but there is no problem on picture. How to fix it please?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
jbob0124, since you found at least one part that does not appear to be right, I would start with that. Replace the color wheel, and while you are at it, do take a look at all the capacitors on your boards. Check for any bulging or leakage. Once you checked and you made sure they are okay, reevaluate after you changed the color wheel.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Looks like the color wheel was the issue. I've replaced the wheel a few days ago, and it has been working as normal.
von
please show me the picture of the color wheel,its also affecting my tv too,thanks a bunch
Bewertung 0
1 Kommentar:
@jen2joe4 what make and model is your TV and what are the issues with it?
von
Antwort hinzufügen
jbob0124 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,350
